1. Stop being a LURKER - join our dealer community and get involved. Sign up and start a conversation.
    Dismiss Notice
The Third-party Inspection and third party inspection
Discussion in 'Websites, SEO, SEM, Display, Social, Marketing' started by qczoomen, Jan 18, 2019.
This forum sponsored by...
  1. qczoomen
    qczoomen
    Expand Collapse
    Noob
    First Name:
    qczoo
    Twitter Handle:
    qczoomen
    Jan 18, 2019
    1
    China
    Process Supervision
    Third party inspection
    To be certain that casting/forging process follow proven procedures
    Heat Treatment
    To be sure that heat treatment is done properly for all parts, that no portion of the product is overlooked
    • Chemical Analysis & Mechanical Property Tests (and Non Destruction Test).To be certain that:
    a) The tests are really carried out
    b) Material certificates use actual test data
    • Assembling
    a) Check internal cleanliness prior to assembling
    b) Check whether quantity, material and type of internal parts meet specification requirements
    c) Check whether construction details of the assembled products comply with specific requirements of the customers, based on Customer's Technical Specification, and /or Customer Approved Drawing
    • Pressure Test
    a) Evaluate whether vendor's pressure test procedure documents meet the standards or client's requirements
    b) Ensure that the medium components of statutory inspection meet standard requirements
    c) Ensure that the pressure test equipment was calibrated
    d) Ensure that the process of pressure test was in accordance with the procedure and standard
    e) Check for leakage or calculate the leakage rate
    f) Ensure that the duration of pressure test and pressure holding meets the standard requirements
    • Paint Application
    a) Inspect pre-processing and surface condition prior to each paint layer application
    b) Measure thickness of each layer applied paint
    c) Pump Inspection
    d) Check protection on un-paint area
    • Dispatch
    a) Check name-plates and, tags
    b) Check whether protections on each product are according to order
    c) Check whether sort and construction of packing box/case are in accordance to order
    d) Check marking on wooden case
    e) Check whether documents in wooden case are according to order
    f) Final quantity check
    http://www.qczoom.com/article_read_46.html
  2. This forum sponsored by...
Share This Page
