Genuine question for the GMs and dealer principals here — when was the last time you looked at your override rate?
Not your close rate. Not your front-end gross average. Your override rate—the percentage of deals where the selling price was changed from the original pencil before the deal was booked in the DMS.
We track this number across a bunch of stores. The average is 11.8%. The average undocumented override costs $178,000 per year per rooftop.
Here's why most GMs don't catch it. The month-end problem
Your DMS gives you a beautiful month-end gross report. Total front-end gross, total back-end gross, total variable gross, gross per unit. All accurate. All correct. What it doesn't tell you is how much of that gross was supposed to be higher.
When a desk manager drops 900 on a deal to close a customer before the weekend, that 900 shows up in the DMS as the final price. Not as a 900 override. Notes on manager discount. Just...the price. By month-end, it's invisible. Multiply that by 30–40 deals a month, and you've got 900 overrides. Notes on manager discount. Just...the price. By month-end, it's invisible. Multiply that by 30–40 deals a month, and you've got $27,000–$36,000 in gross that disappeared without a trace.
The three places it hides
Front-end price reductions — The obvious one. Price drops of 400–400–1,800 per deal, with no reason documented. Your DMS shows it as the transaction price.
F&I product waivers — Less obvious. The finance manager removes the GAP or reduces the service contract price by $300 to avoid customer pushback. The deal closes. The DMS shows the products that sold, not the ones that were waived.
Trade-in over-allowance — The sneakiest one. Instead of dropping the selling price (which would show up in front-end gross), the desk bumps the trade-in by $800 above ACV. Same net effect to the customer, but the margin leak is hidden in the trade line instead of the front-end gross line.
What top stores do differently
The top quartile in our benchmark isn't saying "no" more often. Their override rate is 6% vs. the 11.8% average—lower, but they're still approving discounts when justified.
The difference is visibility:
Every override gets a reason code at the point of entry—takes 10 seconds. GM gets a real-time alert when any override exceeds a threshold (most are set to 1,000 front-end, 1,000 front-end, and 500 F&I)
Weekly report shows override trends by salesperson
A monthly board report shows the full picture before ownership has to ask
The result: top quartile stores leak ~62K/year vs 62K/year vs 178K average vs 280K at the bottom. The delta between the top quartile and bottom quartile score is 280K at the bottom. The delta between the top quartile and bottom quartile score is 218,000 in recoverable gross. Per year. Per rooftop.
For the multi-rooftop groups
It gets worse at scale. If you're running 5 stores and each one has its own override pattern buried inside its own DMS, you have zero way to compare. One store might be running an 18% override rate while the group average is 10%—and you won't know until you pull every deal jacket and manually reconstruct it. Nobody does that.
We publish the full breakdown—override rates by region, by store size, by brand tier, and by department—here: DealerInt — Automotive CRM & Desking Software for Car Dealerships.
And the methodology behind the $178K number: DealerInt — Automotive CRM & Desking Software for Car Dealerships
So here's my question: for those of you managing desks, are you tracking overrides in real time or finding out at month-end? What does your process look like?
