VLA ads and inflated click to calls
Brad Burlingham
4 Pounder
May 28, 2009
76
21
Brad
Hi all, we are seeing VLA ads showing on display network once again and that means a ton of "fake" calls. I saw this happen to us at the end of last year, but its happening again. We discovered it happening at 5 of our dealerships and its happening across several vendors. IF you have access to your google ads account, you can look at pmax campaigns by channel. if you are showing on display network, its a waste of money.
Since google doesnt allow you to turn off display, you need to block certain sites (i'm not talking about the partner network) and rethink what you are optimizing for. If you are including click to call as one of your optimized events, this might be the culprit.
Anyone else having these issues and or have some hacks on preventing it. i hate google!
Hi Brad, Are you running VLA-only campaigns? We have found some of our VLA-only campaigns only show on Search and others run on both Search and Display. Same settings.
For those running on both Search and Display, we use placement and content exclusions to limit the amount of ads showing on Display. There's no way to completely eliminate the Display ads as far as we know because we can only exclude the ads once they show up on Display but this does reduce it by quite a bit.
Hope this helps.
Seen this too. Display network clicks to call are almost always garbage. It's bots or accidental taps. None of them convert.
Couple things that helped us:
Remove click to call as a primary conversion goal in PMAX. Keep it as a secondary or just exclude it from optimization entirely. Otherwise Google will find every low quality placement that generates a call and pour budget into it.
Dealers are experiencing inflated call metrics from VLA (Video Local Ads) and display network placements, with fraudulent clicks from bots and accidental mobile app taps skewing performance data. The consensus solution involves excluding mobile app traffic at the account level, removing click-to-call as a primary conversion goal in Performance Max campaigns, and using placement/content exclusions to minimize display network exposure. The key insight is that click-to-call should not be a primary optimization metric for sales campaigns, as display network calls rarely convert to actual customers.
Replies Views 6 2,304 Started Last Reply
