ADP XR8.02/Reflection Client
iceman101
Dec 15, 2009
71
Jason
I know how to put in the host name or ip address. How can i change the port? Any help is much appreciated.
Thanks!
Oct 14, 2009
260
call me Jason
I don't think there is a way inside the Reflection client. I tried myself. The good news is though, it uses telnet which can be done through pretty much any program imaginable.
trial run:
go to start->run , type CMD and hit enter
In the command window type telnet <your adp server ip> <the port you want to use>
you should get a login prompt.
Now this is assuming the ADP server will accept incoming telnet requests on a different port. If that hasn't been changed it won't work. Also, telnet through the command window is slooow.
iceman101
Dec 15, 2009
71
Jason
trial run:
Thanks for the update. I have found all I needed!
