Can Bad Alignment Ruin New Tires?
Sep 3, 2026
1
Expert Alignment &
I recently started wondering whether getting new tires without checking the alignment can potentially lead to uneven wear again.
From what I understand, alignment determines how the wheels sit relative to the road and each other. If the angles are outside the vehicle manufacturer's specifications, the tires may wear more quickly or unevenly. That seems particularly frustrating after spending money on a new set of tires.
I'm curious how other drivers approach this. Do you have the alignment checked whenever you replace tires, or only when you notice uneven tread wear or steering problems? Also, has anyone noticed a significant difference in tire longevity after correcting an alignment issue?
A forum member raises the question of whether skipping an alignment check when replacing tires leads to premature or uneven wear, noting that misaligned wheels can cause tires to degrade faster than they should. The post invites other drivers to share whether they routinely check alignment with new tire purchases or only when problems become noticeable. The thread centers on the practical and financial case for making alignment checks a standard part of any tire replacement.
Replies Views 0 41 Started Last Reply
