Forcasting
Sep 1, 2009
Chris
Have any of you out here had issues with forcasting? I was just asked this month to give my monthly totals for leads, and then sold units so they can forcast my units for the month.
I have been doing this for a while now, but leads seem to flucuate from month to month, so how can one figure a forcast for this. It was a long night last night so if I am just lost let me know.
Thanks.
Chris
I don’t think you can really set forecasts based on number of leads. But you can set goals, with some forecasts attached. These, In my option, are what they would be looking for. And, this is the first thing I ask a GM.
First thing is to look at is staffing - how many people actually sell cars, and what is your lead to salesperson ratio? This can be debated in great detail (and has A LOT of variables), but I really think that an internet sales person should not handle more than 75 leads a month - and by leads I mean UNIQUE CUSTOMERS, these include internet and PHONE if your department takes inbound phone calls.
So forecast 75 leads per sales person and then back out the numbers for solds:
75 leads = 30 appts = 22.5 appts shown = 11.25 cars sold
This is based on a 40% appt to lead, 75% appts shown, and 50% appts sold
Adjust based on your needs, lead quality (you should be tracking your leads in this same manner), and close rate. I feel these are pretty solid and obtainable numbers, however your mileage may vary. And, if you are not generating enough leads for your salespeople - then look at getting more leads.
If your numbers are good - this is also great logic to use when asking to hire another salesperson. Being able to explain and show what you can forecast for that person really helps justify the cost.
You can use Excel to find out the the forecast(trend)... add your old numbers... Leads and Sales... insert chart... then in chart menu select add trend line.. you can do linear, logarithmic and moving average.. I would do logarithmic since the number of leads fluctuates monthly.
  • A dealer seeks advice on forecasting monthly sales based on fluctuating lead volume.
  • The primary response recommends setting goals based on staffing levels and lead-to-salesperson ratios rather than simply extrapolating from lead numbers, proposing a baseline of 75 unique leads per internet salesperson converting to approximately 11.25 cars sold monthly.
  • An alternative suggestion proposes using Excel trend analysis (logarithmic or moving average) to identify patterns in historical lead and sales data.
A dealer seeks advice on forecasting monthly sales based on fluctuating lead volume. The primary response recommends setting goals based on staffing levels and lead-to-salesperson ratios rather than simply extrapolating from lead numbers, proposing a baseline of 75 unique leads per internet salesperson converting to approximately 11.25 cars sold monthly. An alternative suggestion proposes using Excel trend analysis (logarithmic or moving average) to identify patterns in historical lead and sales data.
Replies Views 3 2,445 Started Last Reply
