Structured Data is Critical for Dealers To Get Into AI Search Results
Just yesterday, Google Chrome released an early preview of WebMCP, which is a proposed web standard that would allow a website to expose structured tools directly to in-browser agents. So instead of an agent having to screen scrape and guess its way through a UI, it can call real functions with defined schemas.
Making your site MCP-compatible for AI agents is a little different than just wanting to show up in AI search results, but having structured data and clearly defined actions on your site certainly can’t hurt.
I agree structured data and clearly defined schemas are good practice. That’s not controversial. Web standards that make machine interaction easier will likely become more important over time.
Where I take issue is with the leap from “good practice” to “primary AI growth driver” and claims that 380 dealerships saw substantial AI traffic spikes after migration.
Structured data:
  • Is not a direct ranking factor.
  • Does not trigger indexing.
  • Does not guarantee AI Overview inclusion.
  • Does not override authority or competitive positioning.
It helps search engines interpret content. That’s valuable. But it is a refinement signal not a traffic lever.
If 380 dealerships saw substantial growth after migration, the obvious variables would be:
  • Improved technical SEO
  • Better crawl efficiency
  • Faster site speed
  • Cleaner architecture
  • Stronger internal linking
  • Inventory freshness handling
Those changes move traffic.
Attributing that lift specifically to schema or “AI readiness” requires isolating schema as the variable, which would require controlled before/after testing and a defined AI visibility metric.
What tool is being used to measure “AI visibility” across 380 accounts? AI Overview citations? Referral logs from AI agents? Impression deltas? Something else?
If schema alone caused large traffic spikes, we would expect to see low-authority but perfectly tagged sites outperforming strong brands without it. That’s not what’s happening in real-world SERPs or AI Overviews.
Structured data is smart.
Overstating its impact is not.
This conversation is going all over the map and it feels like an argument that can't have a winner.
Should you add schema markup to your website? Yes. Irrefutably yes.
Will it be a magic carpet that takes you to the #1 spot? No.
Is it a detriment to not have schema markup? Yes. (AI is not everything)
That's all that dealers need to know IMHO.
When someone comes into the forum, dropping links to their site every time they post and being very misleading in what they are saying, IMHO it needs to be called out, otherwise the forum just ends up being a place for spammers giving misleading information to try and sell their products.
I agree 100%. Thanks for summarizing more concisely!
In other related news, yesterday Cloudflare announced they now support real-time conversion of HTML into AI agent friendly markdown which results in up to an 80% reduction in token usage (so faster responses, lower cost, and more efficient use of the limited context window.)
Markdown isn’t structured data, but it is a meaningful improvement over simply serving raw bloated HTML.
Gregg's point about needing to be competitive in organic first is important and often overlooked. Schema is table stakes, not a competitive advantage. The dealers I see getting cited in AI Overviews have two things in common: (1) they publish genuinely useful, specific content that directly answers real customer questions, and (2) their site experience keeps people engaged rather than bouncing back to search.
The structured data conversation is necessary, but it's step three in a process where most dealers are still stuck on step one: actually creating content worth citing.
I'm not sure what the combination is anymore, but to compete you better be hitting on all cylinders. I definitely wasn't trying to state this was "all you needed."
Dealers debate whether structured data (schema markup) is critical for appearing in AI search results, with the original poster claiming it's essential for AI Overviews and Generative Engine Optimization, while skeptics argue AI models don't inherently rely on schema. The discussion reveals significant disagreement: some participants found testing tools to be inaccurate or misleading, others noted conflicting research on schema's correlation with AI results, and concerns emerged that "GEO" is simply repackaged SEO being sold as a new service. The thread ultimately suggests that while schema *may* help indirectly (through indexing and retrieval layers), it's not the guaranteed gateway to AI visibility that vendors are marketing, and dealers should be cautious about claims that schema markup alone will get them discovered by AI search engines.
Replies Views 29 5,034 Started Last Reply
