Search - it finally works!!!
Alex Snyder
President Skroob
4,079
2,938
Alex
The search function on DealerRefresh has been the worst of any search I've ever used. It was worse than an AOL search after dialing up on a 14K modem. The results were so bad that it felt like you were punched in the face with stupidity. Siri gave better results.
It is fixed!
We built it from the ground up using an open-source indexer that lets you search for short terms like "CRM" (the old search required at least 4 characters). And it can take very broad results as well. The logic is that it seeks results closest to the keywords and also supplies other combinations to broaden the results. It caches results to make faster returns on common searches. When it is a new search, it falls back to Claude Haiku to apply some AI logic.
It is all new and completely our code. If you see anything odd or have ways to improve it, post here. I'm sure it isn't perfect, but I guarantee it beats the snot out of the old dog poop system we used to have (AKA default Xenforo search).
Here are some screen shots so we can remember just how bad that hot garbage search was.
Reactions: joe.pistell
Alex Snyder announces a complete rebuild of DealerRefresh's notoriously poor search function, which previously required at least four characters and returned frustratingly irrelevant results. The new system uses an open-source indexer, supports short terms like 'CRM,' caches common searches for speed, and falls back to Claude Haiku AI for novel queries. Members are invited to report anything unusual as the team monitors the rollout.
Replies Views 0 367 Started Last Reply
