Looking for help from anyone who has dealt with a similar setup.
I have a client with a Ford building and a Chevrolet building on the same campus. Both stores share one VinSolutions CRM and one inbound ADF destination. They do not want to pay for a second CRM / ADF setup, so all inbound leads for both stores are flowing into one shared location.
New-vehicle reporting is workable because I can separate most of it by “New” + OEM make.
The real issue is used/pre-owned reporting.
Used leads from third-party providers, website forms, marketplace sources, etc. all come through the same ADF path. Once they land in VinSolutions, it becomes difficult to tell which store the lead was actually intended for, especially when both stores share inventory and providers.
Questions for the group:
Has anyone successfully managed two OEM rooftops on one VinSolutions CRM?
How are you separating used-lead attribution by store?
Are you using source names, lead comments, inventory make, assigned teams, custom fields, provider-level routing, or another workaround?
Can VinSolutions report on anything passed through ADF comments or custom lead data?
My only idea so far is to create two separate forwarding paths outside of VinSolutions, likely through Google Sheets / Apps Script or a webhook. Each third-party provider would receive either a Ford-specific or Chevy-specific endpoint. That endpoint would then forward the lead into the shared VinSolutions ADF while adding a clear store identifier in the comments.
The concern is that we have been told custom reporting may not be able to use anything outside the default reporting fields. If that is true, comment-based tagging may help with visibility, but not actual attribution reporting.
Appreciate any real-world advice on what has worked, what failed, or what you would do differently.
But usually most dealers decide the imperfect solution is better than potentially doubling the expense just for reporting / lead routing perfection.
