If your dealership website runs on WordPress, check your PHP version this week
Alex Snyder
President Skroob
4,165
3,038
Alex
On October 21, the PHP project released fixes for two serious security flaws in PHP itself. Researchers named them PHP2Shell (CVE-2026-109618 and CVE-2026-109619). WordPress runs on PHP. It also runs a lot of the landing pages, lead forms, and special pages dealers use every day.
An attacker does not need a login, a plugin bug, or a weak password. They send one specially built web request to a PHP page, and on an unpatched server that can be enough to run their own code on it.
Who is affected
Every PHP version from 5.4 through 8.5 that serves web pages, until it is updated. The fixed versions are 8.2.35, 8.3.36, 8.4.27, and 8.5.12. PHP 7.4, 8.0, and 8.1 are past end of life and have no official releases, so sites still on those need to move.
What to do
  1. List every site with your dealership’s name on it. The main site, the blog, service and parts specials pages, old campaign microsites, the landing page an agency built in 2019. Forgotten sites are the ones that never get patched.
  2. Ask whoever hosts each one: “Which PHP version is this site on, and have you applied the October 21 PHP security update (CVE-2026-109618 and CVE-2026-109619)?” Get the answer in writing.
  3. If you’re on a managed WordPress host, they have most likely patched already. Confirm anyway.
  4. If the site sits on its own server or a VPS, someone has to update PHP. If the answer is PHP 7.4, 8.0 or 8.1, ask for a dated plan to move it.
  5. If nobody uses an old site, shut it down or turn it into plain HTML pages. A page with no PHP behind it can’t be hit by a PHP flaw.
One more thing we learned firsthand. Having Cloudflare or a firewall in front of your site does not stop this on its own. The attack looks like an ordinary form submission, so it passes straight through unless someone adds a rule for it.
What we did at DealerRefresh - thanks, @craigh, for the heads-up!
We checked every server the day after the announcement. Like most sites online since 2005, we had older PHP versions in the mix, so this applied to us.
That same day we added temporary blocks for the request patterns the attack depends on, and limited our test server to our own network. Then we built new servers on a current long-term-support release of Ubuntu with patched PHP 8.3, tested everything on staging, and moved the live forum over the next morning.
Our old WordPress blog was the pain. It has 1,784 articles going back to 2005, and nobody has posted there since 2023. Instead of upgrading WordPress and 48 plugins for a site we don’t use, we converted it to static pages. Every article still loads at the same address, and there is no PHP behind it anymore.
While we were in there, we also tightened database access, changed passwords, and added daily backups and uptime alerts.
If you’ve already asked your website provider about this, post what they told you below. Vendors, if you’ve patched your dealer clients, say so here. It will save many dealers a phone call.
Sources:
PHP2Shell: Critical PHP vulnerabilities patched, update now! - Help Net Security
php2shell (CVE-2026-109618, CVE-2026-109619): Critical PHP RCE FAQ | Tenable®
Yeah, we also went through the same process here at Autofusion, adding temporary blocks and extra/more-frequent checks on the netops team until the patch was released. We then applied the patch late at night on our dev environment, did testing and promoted everything to production. We only ran into one small problem, which affected our support tickets but that was fixed within an hour.
Reactions: Jeff Kershner
Yeah, i did pretty much the same thing at Autofusion. Put some temporary blocks in place and had the netops team check more often until the patch dropped. Applied it late at night on dev, tested everything, then pushed it to prod. Only hit one small issue that messed with our support tickets for a bit, but we sorted it out in about an hour.
Applying the patch in dev first and testing before pushing to production sounds like the right call. Even with a late-night rollout, it’s good that the issue was limited to support tickets and you were able to get it resolved within an hour. I’ve found that having a rollback plan and someone monitoring things right after deployment can make a big difference when a patch affects live systems.
Great post. Is anyone automating this today?
Dealers shouldn’t have to manually track every website or old landing page. A system should be able to find them, flag outdated software, and notify whoever is responsible at the dealership.
There are ways to automate parts of this, but I think there are two separate challenges: discovering every website and landing page associated with a dealership, and then monitoring the technology running behind each one.
External scans can help identify technologies and flag potential issues, but they can't always reliably determine the actual server-side PHP version or confirm whether a patch has been applied. For that, you'd ideally need access to the hosting environment or confirmation from the provider.
The discovery part is particularly interesting. Dealerships can have websites, campaign landing pages and older microsites spread across multiple vendors, and it's easy for something to get overlooked.
I'd be interested to know whether any vendors are already offering this as part of their website management services.
A DealerRefresh member raised an urgent alert about two critical PHP vulnerabilities (PHP2Shell) disclosed in October that allow attackers to execute code on unpatched servers without needing a login or plugin exploit — affecting every PHP version from 5.4 through 8.5 until patched. Vendor staff from Autofusion shared their patch rollout process: blocking traffic temporarily, applying updates to dev first, testing, then pushing to production overnight with minimal disruption. The thread closes with a broader call for automated monitoring tools so dealers aren't manually tracking PHP versions across websites and legacy landing pages.
Replies Views 6 1,342 Started Last Reply
