Mac compatibility in a dealership
I totally get where you're coming from with integrating Macs into a dealership. I'm in a similar boat—I use a MacBook Pro 16” M2 for all my marketing tasks. When we were revamping our reception area, I decided to go with an iMac M1 too.
The sleek design fits perfectly, and it looks way better than the HP all-in-ones we had before. As for software, we're currently using CDK as our DMS and plan to switch to PBS next year. Running CDK on my Mac has been pretty smooth via browser access. I haven't tried PBS on Mac yet, but I'm hoping it'll be just as seamless. If anyone else is navigating this transition, I'd love to hear how you're managing. By the way, if you're in need of Windows keys, there's a site that sells them cheaply **removed link** It could be handy if you need to run any Windows-specific apps in a VM. Looking forward to hearing your experiences with Macs in the dealership.
Well, I am happy to report that I got it working! Brand new M1 IMac. I run parallels for CDK and it works amazing. I seem to have forgotten to install one ADP software so accepting payment does not work. So I am gonna tackle that next. But the workaround is frustrating because it's dumb I even have to do it. So the service sends a PHP packet to check OS, But Windows on ARM is not part of the list of verified OS. A hard Check which means if this check does not pass do not run. All because CDK refuses to rebuild their code base like PBS. I have been on 4 calls with CDK and they blamed the Mac and the OS. All that needed to be done was to change one word. So I told them in the last call I had with them to change our server from a "Hard" requirement to a "Soft" one. The guy even said that he does not think they will do that.
Workaround for CDK on MAC
1. Use Parallels
2. Download Fiddler to intercept the packet and change one line from "Hard" to "Soft".
Thats it. No changes on the Regedit, and no additional drivers. In other words... Yes! you can install it on a M1(ARM) based chip and it will function just the same.
Sidenote
-Technically not support the latest build of Windows 11 and Windows 11 is not listed as compatible. Only Windows 10.
-It runs on .Net 1.1 so expect Zero security since 1.1 came out in 2003 and has long since lost security updates.
-Runs a version of Acrobat that is so old you can't download it from Adobe. (2008)
-Runs on IE! So basically it runs in a comablity mode.
-Must be MS-DOS based because it seems to have an emulator for MS-DOS
Hey, I hope you are doing well.
Do you mind sharing with me what has to be done in Fiddler? I am completely lost there.
Thank you in advance!
1. Use Parallels
Sidenote
I know for sure that CDK and PBS can run on Mac through browsers such as Safari or Chrome. Switching to Imac is a great decision for you. If something doesn’t install, you can still use the web version. I had only one problem, I couldn't install a very important program. I read the forum and was advised to do a factory reset macbook, read how to do it correctly https://moonlock.com/factory-reset-macbook and did it strictly according to the instructions. The problem was immediately resolved. I don't know what the problem really was. Most likely just some kind of lag.
Everything went smoothly with my MacBook too. In fact, this is top technology. Rarely do problems happen with it or something does not start.
Reactions: Fullsend
To all my Mac people. (Marketing Department).
I present to you PBS Systems running on a IMac M1.
It was so easy. Parallels and downloaded the DMS.
Worked out the gate.
Took exactly longer type in the domain for PBS then it did for it to work.
Reactions: ssotop and Carsten
A dealership marketing professional explores running CDK and PBS DMS software on Apple Silicon Macs, sharing hands-on results after ordering an iMac M1 for front reception. CDK proved frustrating, requiring Parallels and a server-side config change from a 'hard' to 'soft' OS check after CDK support blamed the Mac rather than their own legacy code. PBS, by contrast, installed effortlessly via Parallels with virtually no friction, highlighting a clear compatibility gap between the two DMS providers.
Replies Views 33 16,483 Started Last Reply
