MCP from CDK & Reynolds and other DMS companies
This sure would be nice. As for a time frame... you know they are going to holdout as long as they can.
I found your LinkedIn post about this thread funny. All the responses are from vendors overcomplicating the question. A few sounded offended that the question was even posed. I wonder what they fear :thinker:;-)
would be curious to hear your thoughts on what MCP is at this point. lots of variations I have heard.
I think the MCP connection is quite clear as the AI solutions define it.
Perplexity said:
MCP stands for Model Context Protocol. It’s an open standard that lets AI applications connect to external tools, data, and software through a common interface.
Think of it as a universal connector for AI: instead of building a separate custom integration for every AI assistant and business system, developers can expose a system’s capabilities through MCP so compatible AI applications can discover and use them.
How it works
  • The AI application is where you make a request.
  • An MCP client within that application connects to an MCP server.
  • The server exposes capabilities—such as searching documents, looking up a customer, or executing an action—and describes how to use them.
For example, a CRM’s MCP server could let an assistant look up customer information or prepare an update using natural-language requests. What the assistant can actually do depends on which capabilities the server exposes.
How it differs from an API
An API provides access to a particular service. MCP provides a standardized way for AI applications to discover and use capabilities, often by calling that service’s existing API behind the scenes. It doesn’t replace the API; it adds a consistent, AI-facing interface.
MCP is the connection standard—not the AI model or the agent deciding what to do.
For a dealer scenario, I like to think of it in levels of data exposure. One level is where the numbers the dealer can already see in a dashboard are received via MCP to help build a larger dealership dashboard and make month-end reporting more efficient.
Things get deeper when the data behind the numbers is available, thus giving the dealer the ability to act on it. That can be as simple as a list of customers, cars, parts, services, or dollars, depending on what the system specializes in.
And then there is deeper access, like how customers engaged, click paths, pricing changes, etc. This is where dealers can be empowered to vibe-code their own solutions.
@David Steinberg just released a very cool MCP at FourEyes. He's given dealers deep enough data levels to build solutions.
Reactions: AlexCaradonna
And they never "follow directions." Rather comment here in the forums where it's much easier to search and reference back to, they keep their comments on LinkedIn.
Under on the label. Over on the substance.
Every DMS will ship something called MCP within 12 months. Marketing will demand it.
But MCP is a pipe. It is not the data.
A DMS MCP gives an agent one system's view. The dealership runs 10 to 12 other tools. The records are duplicated and dirty. Point an agent at that and you get confident wrong answers.
And if the Tekion upcharge is true, that is the real story. Certified API access already runs $300 to $800 a month, and no program gives a dealer all of their data. An MCP fee is the same toll with a new name.
Before any dealer pays for it, ask five questions:
1. Can I connect my own Claude or ChatGPT, or only your agent?
2. Which fields are exposed? All of them?
3. Read only, or can it write?
4. Who controls permissions and the audit log on customer PII?
5. What do I keep when I cancel?
The dealers who win will own a clean, unified copy of their data first. Then the pipe matters.
Owners, not renters.
*linkedIn vca
I can give an honest opinion from both sides. I previously operated two dealerships, and now I’m the founder of LotIQ.
I think CDK and Reynolds can release something called an MCP within 12 months. Meaningful access will take longer—probably two to three years unless competitive pressure accelerates it.
The technology is not the difficult part today. The real questions are what data dealers can access, whether outside agents can use it, and whether the connection can take actions or only read reports.
Read-only dashboard data will come first. Record-level access will follow. Permissioned write access—updating customers, inventory, appointments, repair orders, or deals—will be the last and most valuable stage.
If an MCP only works with the vendor’s agent, exposes limited fields, or adds another access fee, it is essentially the same closed system with a new interface.
The real test is simple: can the dealer connect its own agent, securely access its own data, take approved actions, and keep that data if it changes providers?
Dealers and vendors debate how soon CDK, Reynolds, and other DMS providers will offer Model Context Protocol (MCP) connections, with Tekion reportedly already charging extra for it. The consensus is that DMS companies will ship something branded as MCP within 12 months, but meaningful data access — especially permissioned write access — could take two to three years, and the real concerns center on data quality, pricing, security of sensitive customer PII, and whether dealers can connect their own AI tools or only the vendor's. The thread surfaces deep skepticism that early MCP offerings will be little more than costly rebranded API toll gates rather than genuine dealer empowerment.
Replies Views 10 386 Started Last Reply
