Missed calls: How are you guys handling callbacks at your store?
Cameron Weston
Nov 11, 2026
4
Cameron
Hey ya'll :)
After lurking for a bit and reading some posts in other dealer forums, I've noticed that missed calls seem to be the biggest recurring complaint from dealers and marketing.
This got me thinking and I feel like logging the missed calls is the straightforward part, but the hard part is knowing WHY it was missed and who takes ownership of calling back.
I feel like an automation flow (like n8n or zapier or Make, etc.) could solve this pretty easily.
Here's a pretty simple setup that costs basically $0:
1. Have your call tracking send a missed call report every 10 minutes or something
2. Send that email into a google sheet with zapier or make (free plans work). One new row per missed call.
3. Add 2 columns: owner and called back Y/N. sales calls go to the BDC lead, service and parts calls go to that dept manager
4. Anything still "N" after 30 MIN gets a reminder to the owner.
Not fancy but it makes sure every missed call has a name next to it.
Curious how ya'll are handling this now? With AI and automation tools so accessible, I'm curious to hear about the flows or systems you guys have created to handle this. Thanks!
The sheet is the easy part. Where it breaks is ownership, especially on a Saturday when the BDC has gone home. Somebody needs to own every missed sales call, and the desk needs to check the list at shift changes. I'd also look at why the calls are being missed in the first place. If they're ringing to somebody who's out on a demo, fix the routing. A missed call returned quickly is still an opportunity. Wait until tomorrow and you may have lost it.
Reactions: Cameron Weston
Vendor disclosure up front — I work at ASN Software, we build the DMS/CRM a lot of independent stores run on. Your instinct is right: logging is the easy half. Two things I'd add from watching this break in real stores:
1. The sheet becomes a second system nobody opens. The callback needs to live where the customer record already lives — in the CRM — so the next person who touches that customer sees the missed call, why it was missed, and who owns it, without opening a separate sheet.
2. The owner needs a backup. Your 30-minute reminder is good, but when the owner is out, on another call, or off that day, the row just sits at 'N.' The rule that actually closes the loop is: if the owner hasn't called back in X minutes, it escalates to a named second person automatically — nobody's inbox, a name.
One more piece worth adding: text the caller back right away, even before the callback. A quick 'sorry we missed you, what's the best time to reach you?' keeps a lot of them from calling the next store while they wait. The callback still belongs to a human — the text just buys you the time to make it.
Good setup for $0 though — the owner column is the part most stores never get to.
The sheet is the easy part. Ownership is where it breaks.
What works across our 10 stores is that every missed call routes to one department by the line it came in on, with a 15 minute callback SLA and a named owner per shift. If it isn't called back in 30, it escalates to the manager.
We also had AI call back after hours to qualify and book, so humans start the morning with appointments instead of a list.
This is actually extremely helpful and insightful @DealDeskCoach Thanks for sharing your wisdom/experience.
Great! What does your ai automation pipeline look like? And can I ask what tools you are using?
A dealer professional proposes a low-cost automation flow using tools like Zapier and Google Sheets to track and manage missed call callbacks, sparking a focused discussion on where such systems actually break down. The consensus from experienced operators is that logging is the trivial part — the real failure points are ownership gaps during shift changes and after hours, and the fact that a standalone spreadsheet becomes a second system nobody reliably checks. The practical fix that emerged: callbacks must live in the CRM, escalate automatically to a named backup if the SLA isn't met, and after-hours gaps can be bridged with AI outreach so staff start the day with booked appointments instead of a cold list.
Replies Views 5 261 Started Last Reply
