As some have mentioned, Power BI is definitely a great choice, capable of handling large volumes of data. There is a learning curve when it comes to designing reports, but it’s definitely doable, and it doesn’t require coding.
The challenge would be ensuring that you have the capability to extract data. Some DMS systems are strict about sharing data through APIs.
It’s also possible that many of the platforms you use are supported by Microsoft Power Automate, which allows you to use ready-to-use integrations to push data into Power BI regularly. If no integrations are available, you can always access data directly using APIs (if available).
To sum everything up, the first step would be to determine if you have the capability to read data via some sort of integration of extensions austin; otherwise, you’ll be blocked from achieving your use case.
Yes it works for me
I don't even know if that's the correct terminology. What we're looking for is a program that we can take all of the many data sources we have and put them into one spot and create measurable metrics once the data has been ran against similar relevant data.
We just have so many different avenues that data is being collected, it's like drinking through a fire hose.
- Marketing
- CRM
- DIS
- Purchasing
- Service
I could go on but those are the main ones that we want to be able to put into a system, tell that system the guidelines we want to fall within, and be able to at a glance, in real time, notice if there's an issue before it's too late.
Thank you very much!
What did you end up doing?
- Marketing
- CRM
- DIS
- Purchasing
- Service
In practice, we also use Wrike, connected through integrate wrike on LateNode, to help manage all the workflows that come from these different sources. It’s not just for tasks—it can centralize projects, track deadlines, and even feed data into dashboards so your team can see real-time progress and spot bottlenecks before they become a problem. It’s especially handy when you have multiple departments contributing data at different times.
The usual approach is to pull data from all those different systems (CRM, marketing platforms, purchasing, service, etc.) into a central repository such as a data warehouse, and then build dashboards and alerts on top of that data.
Tools like Power BI, Tableau, Looker, and similar platforms are commonly used for this. They can combine data from multiple sources, calculate KPIs, track trends over time, and notify you when something falls outside the thresholds you've defined.
The real challenge isn't usually the dashboard itself—it's getting all the data cleaned up and standardized so that records from different systems can be compared accurately. Once that's done, creating real-time metrics and exception alerts becomes much easier.
Reactions: craigh
Blair, I’d call it a dealership data warehouse with reporting and alerts built around it.
The dashboard is the easy part. The hard part is getting the CRM, DMS, marketing, purchasing, inventory, and service data to agree on the same customer, VIN, deal, and store.
Once that’s clean, you can set the ranges you care about and have it flag things like leads sitting too long, aging units, recon getting backed up, or ad spend climbing without sales following.
I’d be careful with anyone promising true real time. You’re only as real time as the feeds coming in.
If the data underneath isn’t clean, it’s still the same fire hose just with better graphics.
Reactions: Vochi and craigh
What you're looking for is a Business Intelligence (BI) or Business Performance Management (BPM) platform.
These tools combine data from multiple sources (CRM, marketing, purchasing, service, etc.) into one dashboard, allowing you to track KPIs, monitor real-time performance, and receive alerts when something goes outside your defined thresholds.
Popular options include Microsoft Power BI, Tableau, Zoho Analytics, and Qlik Sense.
- Marketing
- CRM
- DIS
- Purchasing
- Service
This is certainly easy to do today with AI everywhere, but I think the biggest downfall of a self managed system is exactly that it is self managed.
Do you save money hosting and managing everything yourself? Of course. But do you really want to spend time during work, after work, or on your day off uploading data, or triaging broken data pipe lines? Probably not.
I imagine there will be a long list of dealer created solutions that try to offer this to the wider market.
- Marketing
- CRM
- DIS
- Purchasing
- Service
The problem is your data belongs to your vendors, not you.
Every time you change a CRM, a DMS, or a marketing platform, they take the most important part of your store with them!
You are renting your own history month-to-month.
Instead of buying another dashboard the entire process needs to flip:
  1. Make your core web and database layer the primary source of truth.
  2. When a third-party CRM, DIS, POS or so on pushes data, your system should instantly capture, normalize, and mirror a local copy of those customer records, notes, and transactions on your own backend.
  3. Third-party tools become optional plugins rather than gatekeepers. If a vendor jacks up their rates, gets hacked, or you decide to swap them out, you flip an API switch. The vendor leaves; your data, history, and customers information stay.
I've been helping dealers use Power BI for this. IT really depends though how all your different apps allow other apps to integrate.
It's powerful and simple to use https://powerbi.microsoft.com/
Power BI is reading data from ten different systems, those ten systems still own your history, your just reporting on it!
It's treating the symptom while ignoring the disease.
The problem isn't that your charts aren't pretty enough, the problem is Power BI is only as good as the data pipelines feeding it.
If you have 15 to 20 disconnected systems (CRM, DMS, service, marketing) all maintaining their own separate versions of a customer or a deal, Power BI just gives you a high-definition dashboard of a fragmented fire hose. You still run into three major problems:
  1. You are entirely at the mercy of how well your vendors allow you to pull data. Many DMS platforms lock down APIs or charge heavy extraction fees precisely to prevent you from doing this easily.
  2. Power BI doesn't automatically know that "Robert Smith" in the CRM is the same person as "Bob A. Smith" in the service scheduler. This could cause your reports to have blind spots.
  3. Unless you have a dedicated data engineer on staff to to fix broken API pipelines, gateway refreshes, and schema changes every time a vendor updates their software, these dashboards get abandoned.
Dashboards are great for looking backward at what happened. But a dealership running on a 30-day clock doesn't just need a better mirror, they need an operating layer that captures and unifies the intelligence before it gets locked away in twenty different vendor silos.
Can anyone recommend a good online auto repair estimator? Basically, I want to know how much labor time is going to be needed to do the repair, before I approach a shop. Access to AllData would be great, of course, but that costs way too much.
I know I can ask here for specific jobs, but I like to find out as much on my own first before consulting the hive mind.
Every time a shop does a job, they figure out the tricks, the actual labor hours it takes, which parts fail, and what fixes it the first time.
But that knowledge lives in the technician's head, or gets buried in a closed repair order system, and leaves when they quit.
Instead of paying a fortune for generic external estimators that don't know your specific shop, this data should be built directly into the operating system of the business:
When a mechanic or a service writer logs a customer complaint, the system shouldn't search a manual, it should search your dealership's internal memory:
  1. "We’ve repaired this exact issue 41 times across similar models."
  2. "Solution B has a 94% success rate."
  3. "Average actual labor time in our bays is 4.1 hours, and average parts cost is $238."
The shop gets smarter with every single repair order, cutting diagnostic time down to zero.
Instead of a generic website landing page, imagine flipping that same intelligence outward to the consumer:
  • When a customer describes a problem, the public-facing portal or AI assistant can show them real historical context, not generic internet guesses, but proof of your shop's actual track record (e.g., 4.8-star satisfaction across 41 similar builds).
  • For used and new car questions, the page doesn't just list specs; it searches your specific service department to find out about ownership costs, common failures, and custom upgrade paths.
In the coming years, a dealership's physical lot, building inventory, and franchise agreements will be commodities. The only true defensible asset will be the institutional knowledge the business has accumulated and preserved.
If you build an operating layer that captures your own repair history, customer preferences, and technical breakthroughs instead of renting them from a third-party database, you stop being a 30-day business and start building an enterprise that actually remembers.
I agree with about 90% of what you are saying, however, building a traditional data warehouse and slapping a BI tool on top of it still treats the symptom rather than the disease, for two major reasons:
  1. Traditional data warehouses rely on continuous API extraction from legacy vendors who have zero incentive to make data portability easy. When a DMS provider locks down their API or changes schemas, your ingestion pipelines break, and your warehouse goes dark unless you have a dedicated data engineer on payroll to fix it.
  2. Dealerships run on 30-day pay plans, floor plans, and factory resets. Asking an operator to manage a complex data warehouse infrastructure alongside their monthly board resets usually results in an abandoned initiative by quarter two.
In my humble opinion, the shift that needs to happen isn't building better data pipelines to sync siloed vendors.
What if the database layer itself is unified from day one? If the CRM, website, service scheduler, and inventory all write back to a single core operating layer natively, instead of living in twenty disconnected applications, there is nothing to "sync" or "clean up" across pipelines.
Dashboards and alerts are no longer a problem if the business stops renting its memory and owns its infrastructure.
A dealer asks how to consolidate data from marketing, CRM, purchasing, and service into one real-time dashboard with threshold alerts. Respondents identify the solution as a Business Intelligence or Business Performance Management platform, with Power BI, Tableau, and Qlik Sense cited as options, but the thread quickly pivots to the deeper problem: vendor-owned, fragmented data means dashboards are only as good as the underlying pipelines. The key insight is that stitching together 15-20 disconnected systems is a brutal engineering challenge, and the real goal is a single clean identity layer for customer, vehicle, and deal data sitting beneath whichever tools dealers already use.
Replies Views 23 17,105 Started Last Reply
