REVIEW Community Review: eLead
admin
Administrator
97
1
DealerRefresh
Community Review: eLead CRM (ELEAD1ONE / CDK)
Synthesized from 67 threads on DealerRefresh
Overview
eLead — marketed over the years as ELEAD1ONE and now operating under CDK Global following its acquisition — is one of the most widely deployed automotive CRM platforms in the industry, with roots in internet lead management (ILM), BDC operations, desking integration, and fixed ops tools. It serves thousands of rooftops and has been a fixture in dealer technology stacks for well over a decade. But as the community discussions make clear, its trajectory has become a cautionary tale about what happens when a beloved independent platform gets absorbed into a large corporate structure.
What Dealers Say: The Good
  • Integration depth is real. eLead has long been praised for its ability to connect with DMS platforms, desking tools, and third-party vendors. ActivEngage notably announced it was the first automotive chat solution to push lead data directly into eLead via a native API — a meaningful workflow win for dealers running both tools.
  • Reporting is extensive — when you can get to it. The platform has a wide library of reports including source/subsource tracking and campaign performance. Dealers who have learned the system note that many reports simply need to be activated by a rep, which can be a discovery process in itself.
  • It's trainable. Multiple dealers across multiple threads noted that eLead is relatively easy to onboard staff to, especially those coming from Reynolds or Higher Gear. One new employee posted asking for a quick-start guide and received enthusiastic community support — and reported success shortly after.
  • Campaign management tools have real utility. The platform's campaign manager supports GM manifest list uploads at no additional charge — a feature that won at least one dealer over from iMagicLab, which charged per import.
  • Sticky for a reason. One dealer who experienced a full-day outage two years prior confirmed they were still on eLead — citing the operational and cultural burden of migrating an entire sales team as the primary reason. That kind of stickiness reflects genuine embedded value, even if it's partly inertia.
Common Concerns
  • Support has fallen off a cliff. This is the most consistent complaint across recent threads. Since acquisition-related transitions moved support operations, dealers report hold times of 20–60 minutes, voicemails that go unanswered, and issues sitting unresolved for weeks. One thread revealed that an employee confirmed impending layoffs during the Genpact transition period.
"Multiple dealers confirm the problem is widespread and attribute it to the company's ongoing transition of support operations overseas, with one employee revealing impending layoffs." — Thread: Warning for Elead CRM dealerships on customer service
  • Reporting has a ceiling — and it's not high enough. While the report library is wide, pulling data programmatically is painful. There's no native reporting API; dealers who want custom scorecards or data warehouses are pointed toward Fortellis APIs and DIY ETL pipelines — a solution that requires significant technical resources unavailable to most dealerships.
  • The platform is showing its age. In head-to-head CRM comparisons across dozens of threads, eLead is consistently grouped with VinSolutions and DealerSocket as legacy platforms being outpaced by DriveCentric and others. A 12-store group was actively seeking to leave eLead entirely, citing stagnation.
  • Feature gaps in areas that matter. One dealer was frustrated to discover eLead couldn't run campaigns or generate reports specifically targeting certified used vehicle customers — a gap the vendor reportedly dismissed by saying "nobody has asked for that before." Close rate reporting (front-half vs. back-half) is also a known gap, requiring manual calculation.
Notable Mentions
  • The CDK cyber attack was a watershed moment. When CDK's systems — including eLead CRM — went down in a major cyber attack, dealers across the country lost access to both their DMS and CRM simultaneously. The incident sparked serious discussion about vendor dependency, data security, and the need for contingency planning. One company used the outage publicly to make the case for technology diversification.
  • BDC/ILM services are a mixed bag. The eLead CRM platform itself is generally regarded as operationally solid for ILM workflows. However, at least one dealer reported that eLead's call center arm used aggressive appointment-setting tactics and delivered questionable lead quality — a distinction worth making when evaluating the platform vs. its managed services.
  • ActivEngage integration milestone. ActivEngage announced it was the first and only automotive messaging solution to natively push chat lead data into eLead's CRM via a direct API — cited as a genuine improvement for dealerships running both tools.
Overall Verdict
eLead built a strong reputation as one of the most capable independent CRM platforms in automotive retail — and the community's long history of recommending it reflects that legacy. But the conversations have shifted. Post-acquisition support quality has become a serious pain point, the product roadmap appears stagnant relative to newer competitors, and multi-rooftop groups in particular are actively looking for the exit.
If you're already on eLead and running a single-point store with a trained team, the migration calculus may still favor staying put. But if you're evaluating CRMs fresh in 2024, the community consensus is clear: eLead is no longer the forward-looking choice, and platforms like DriveCentric are pulling dealers away for good reason.
This review was synthesized from 67 community threads on DealerRefresh. Experiences vary by rooftop, region, and account configuration. Always request a current demo and speak with active users before making a platform decision.
This community review synthesizes 67 DealerRefresh threads on eLead CRM, covering its strengths in ILM, BDC operations, and desking integration that made it a go-to platform for thousands of dealerships. The central tension running through the discussion is how CDK Global's acquisition transformed a well-regarded independent tool into a cautionary example of what corporate consolidation can do to a dealer-focused product. Dealers weighing eLead today will find a platform with deep functionality but a community increasingly skeptical of its post-acquisition direction and support.
Replies Views 0 1,301 Started Last Reply
