Data Your Way?
Agreed, definitely make sure you have their data dictionary on hand when navigating the large number of tables and fields available.
The data dictionary is our devs new best friend haha I wish CDK would allow us to query that PostgreSQL database they use to generate the file exports from. Currently our dealer partners are needing to generate 250+ separate report exports in order to get all of the data..we end up just cherry picking a handful instead, but ideally we would like all of the data without needing our dealer partners who are a little less tech savvy needing to setup so many separate exports.
Have you found any workaround to do a mass export?
Dealers share practical experiences implementing CDK's Data Your Way product to export DMS data and build custom reporting for their dealership groups. Key takeaways include: the setup is relatively straightforward with good CDK support, but requires technical expertise to navigate the complex schema and PGP encryption; users successfully combine this data with CRM, GA4, and other sources in data warehouses (often on AWS) to gain insights into customer behavior and operations. A significant limitation emerges—CDK prohibits third-party IP exports and doesn't allow direct database queries, forcing dealers to manually configure hundreds of individual exports rather than doing bulk extractions, which creates friction for less tech-savvy users.
Replies Views 10 6,252 Started Last Reply
